C ColeWilliamz Lurker Mar 6, 2011 #1 I wanna use it to replace Motoblur, but im curious on how it works. Will i be stuck with it? Or can I just go back to Motoblur whenever I please?
M MyNamesTooLong Android Expert Mar 6, 2011 #2 You can delete it anytime...never saw the point in home replacements though
L Lukehluke Android Expert Mar 6, 2011 #3 Its an application that will just replace the Motoblur, however you can uninstall it and Motoblur will go back to being the default Launcher.
O operant Well-Known Member Mar 7, 2011 #4 If youre just looking to replace the look of motoblur, I'd take a look at zeam. Very simplistic and light, yet has a pretty good feature set. If you're looking for more options, go LauncherPro. And you can uninstall at any time, it doesn't hurt your phone at all.
