M MJ46 Newbie Aug 9, 2018 #1 I have a microSDHC card (32gb), and I wish to use it in my phone. There is currently content on it. Will I have to format it in Windows first, if so what format? Or will I get the option to do that from the phone? Thanks.
M MJ46 Newbie Aug 10, 2018 #3 Dannydet said: What content is on it already? Click to expand... I've recently had to use it to update a satnav device, although I won't need it again for that.
M MJ46 Newbie Aug 10, 2018 #6 Windows formatted the card, and success ! The only other problem I have is getting it to stay in without it popping out.........
Dannydet VIP Member Aug 10, 2018 #7 You need to push it in until it clicks. You may need to use your fingernail or a pin
M MJ46 Newbie Aug 11, 2018 #8 Yes, it's gone in and stayed in this time. Works perfectly. It asks me if I want to set it as internal storage. Presumably yes?
psionandy Extreme Android User Aug 11, 2018 #9 Sure... you can do that.. it will let your phone use it to save apps on.. the downside is that if you do, it won't be readable on your pc.
M MJ46 Newbie Aug 26, 2018 #11 MJ46 said: That's OK, I need it for the phone anyway. Click to expand... Sorted.
