Help Using flash for notifications help
KutuluKid
Ok, so I just got a Spiegen clear case and noticed that when the flash lights up, it catches the edge of the case around it and lights the whole thing up. What I can't do is find an app to accomplish this. Tries Lightflow lite and a few other less risky looking ones from the play store, but none seem to work.
So you're looking for an app that would use the LED camera flash as a notification light?
Lightflow would have been my first guess too, but I'm not sure that it supports using the camera flash (only the built-in notification LED). I'll move your thread to the Android Applications subforum to see if anyone else has some bright (get it? ha!) ideas. :thumbsupdroid:
