using keypad, android or touchpal
ZXRichie
Hi, having great fun with all these apps, however a couple of things keep bugging me, when ever i'm using the key pad, it pops up, how do i get it to 'pop' down!
also whilst composing text, if i notice a spelling mistake, how do i go back to it, without using the delete key, fixing it then retyping, i've tried tapping the screen , but my aim is not very good, what i need is a back and forward button etc
rich
Tap the back/return arrow on the bottom left of your phone.
rich
I would suggest the word recommendations from the phone. They can be found between your keyboard and the screen you see the text on. The best match is underlined in yellow.
FL
If you mean the hard buttons which normally backup through your selections, yep that seems to work, Thanks
As for the cursor movement, basically what you're saying is that there is none.....
Rich
