corvairbob
i was watching a youtube that talked about using t-mobile for getting tv and internet. i have metro so will metro allow this being they are part of t-mobile? when i ust an app that shows me what cell tower i'm on it says t-mobile.
anyway has anyone used one of those kuwfi radio devices to get either metro or t-mobile as there internet and something called binge watching?
the you tube showed how to take a t-mobile sim card and get that kuwfi radio connected to a t-mobile tower and then using something on t-mobile for getting free tv networks like netflix and a bunch of other networks for watching tv.
so using this radio for the network looks easy enough but what plan would someone need to be able to use the internet like having comcast so i would not get data caps. currently i do not get close to them but if i was to get on t-mobile and start using that for tv i'm sure i would be into tons of data. comcast gives me 1054gb before they say i'm at the limit. and i do not watch tv on the internet but for netflix, i'm betting if i watch a lot of netflix that data will go up.
so the youtube told about binge watching and internet. using the kuwfi radio and a t-mobile sim card for the service? can anyone tell me it this will work? using it for internet and that tv watching? for normal local channels we have antenna on the roof but for things like netflix i would want to keep that and if there are other networks maybe some of them. thanks
