using my own mp3 as a ringtone
leopalmer
Can anyone tell me how to use my own mp3 as a ringtone please? i have copied the mp3 to my sd card but have no idea what to do next. this is my first android phone so i am a little lost. the phone is an LG LG Optimus Me P350
Greetings leopalmer,
I'm guessing you had your SD card connected to your computer. The easiest thing to do is reconnect the SD to your computer.
On the card create a folder called ringtones if it doesn't already exist. You can also create a folder called notifications.
Copy the ringtone you created to the ringtone folder. The file probably has to be a .mp3. After your re-insert the card into you phone, your self made ringtone should now be available to use.
Placing a file in the notifications folder, will allow your own creations to be used for text and sms alerts.
There are a number of apps that will allow you to make ringtones and notifications out of music files already on your DS card.
Ringtone maker is on of them.
https://play.google.com/store/apps/...251bGwsMSwyLDEsImNvbS5oZXJtYW4ucmluZ3RvbmUiXQ..
Hope this helps
