Hi,
I am trying to get some some processing code via the processing-core library to to be implemented from the broadcast receiver in some alarm manager code in Android Studio.
I started by creating a simple alarm manger App that fires an alarm every minute (user settable) and this works fine. I then created an App that makes use of the processing-core library (imported the library as a jar dependency into android studio) and this also works.
The next step was to amalgamate the above and create an App that fires a sketch class from the broadcast receiver that includes some simple processing code but i am unsure as to how i do this.
My attempt at doing this is shown below. The only class that creates errors is the broadcast receiver class which creates errors related to frameLayout, setContentView and Fragment.setView.
Any help with this is much appreciated.
Cheers.
All classes and XML file are shown below:
MainActivity.java
Activity_main.xml
MyBroadcastReceiver.java
Sketch.java
Cheers.
MainActivity.java
Code:
public class MainActivity extends AppCompatActivity {
private PApplet sketch;
Button start;
@Override
setContentView(R.layout.activity_main);
start= findViewById(R.id.button);
start.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View view) {
startAlert();
public void startAlert(){
EditText text = findViewById(R.id.time);
int i = Integer.parseInt(text.getText().toString());
Intent intent = new Intent(this, MyBroadcastReceiver.class);
PendingIntent pendingIntent = PendingIntent.getBroadcast(
this.getApplicationContext(), 234324243, intent, 0);
AlarmManager alarmManager = (AlarmManager) getSystemService(ALARM_SERVICE);
alarmManager.set(AlarmManager.RTC_WAKEUP, System.currentTimeMillis()
+ (i * 1000), pendingIntent);
Toast.makeText(this, "Alarm set in " + i + " seconds",Toast.LENGTH_LONG).show();
Activity_main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
tools:context="com.example.alrmmngrplusprocsktch.MainActivity">
<Button
android:id="@+id/button"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:text="Start"
android:layout_alignParentBottom="true"
android:layout_centerHorizontal="true"
android:layout_marginBottom="103dp" />
<EditText
android:id="@+id/time"
android:layout_alignParentTop="true"
android:layout_marginTop="22dp"
android:ems="10" />
</RelativeLayout>
Code:
public class MyBroadcastReceiver extends BroadcastReceiver {
@Override
public void onReceive(Context context, Intent intent) {
FrameLayout frame = new FrameLayout(this);
frame.setId(CompatUtils.getUniqueViewId());
setContentView(frame, new ViewGroup.LayoutParams(ViewGroup.LayoutParams.MATCH_PARENT,
ViewGroup.LayoutParams.MATCH_PARENT));
sketch = new Sketch();
PFragment fragment = new PFragment(sketch);
fragment.setView(frame, this);
Sketch.java
Code:
import processing.core.PApplet;
public class Sketch extends PApplet
int x = 0;
double h, h2;
public void settings()
fullScreen();
public void setup()
background(0);
noStroke();
fill(102);
public void draw()
//background(0);
h = height*0.2;
h2 = height*0.6;
rect(x, (float)h, 1, (float)h2);
x = x + 2;
