redintegra
Has anyone used the V30 with headphones that have similar impedance? Can V30 drive headphones with this much impedance? I'm looking at the Beyerdynamic DT 990 250 ohm heaphones.
Thanks!
Thanks!
I'm exactly using the Beyerdynamic DT 990 250 ohm headphones. I like them. Sharp sound. The V30 drive them flawless... And they are very good with tidal...Has anyone used the V30 with headphones that have similar impedance? Can V30 drive headphones with this much impedance? I'm looking at the Beyerdynamic DT 990 250 ohm heaphones.
Thanks!
That's very easy. Any USB-C to USB-A adapter will do. If you have a Dragonfly Red you should try USB Audio Player Pro with it to set the digital volume control properly - older/lower models with analogue control don't require this, though the choice of music player will still make a difference to how it is driven.If I can find a dongle or adapter to try my AQ Dragonfly on the V30 I will give it a fair shot.
Thanks for the advice and I will give it a try. I’ve read those c to a adapters will not work for output?That's very easy. Any USB-C to USB-A adapter will do. If you have a Dragonfly Red you should try USB Audio Player Pro with it to set the digital volume control properly - older/lower models with analogue control don't require this, though the choice of music player will still make a difference to how it is driven.
