Help v6.0.1 update stopped firewall from working and bluetooth issue
I've used mobiwol for a couple of years on an s2, and just moved to a s6 Edge, but since the update its stopped allowing wifi and mobile connections. Not sure if I it was an app I had blocked, so I downloaded more no root firewalls and none of these worked either.
Anyone else having this issue, or know of a firewall that works and has features such as blocking background apps?
Also, the Bluetooth keeps turning itself on. Whether it be mobile or wifi data, more often than not I unlock the phone and the BT is on. Repeatedly turning it off nor restarting helps
** sorry but I posted this in the Android Questions forum simply because I didn't realise there was a specific forum area for the s6 edge.
