Changelog For v4.2:
* Fixed issue with no Setup Wizard you can now setup the OS without getting a force to transfer issue
* Updated Gmail, YouTube, Play Store Etc
* Added AdAway
* New ctOS Bootanimation
* Support for Most S4 Models via flasher & OS
Changelog For v4.1:
* Updated CGS TV to v1.8.1
* Model has been temporaily removed
Changelog For v4.0:
* Changed Flasher method
* Model is set to GT-I9505
* OS can now be installed on all OS
* Over clocked GPU to 487MHz
* Updated YouTube, Gmail,Play Store & Google Play Services
* Added Google Search Lite
* Improved Many features of the OS
* New boot animation
* OS is now ctOS™
* Added Our New Free Movie Service "CGS TV" that was introduced in ctOS 10™
* Added Theming Interfacer v16 for subtratum
BUGS: baseband will say unknown and may not be fixed at all!
Changelog For v3.2:
* Improved Browser
* New Samsung Bootanimation
* Flasher will now format internal storage
* Updated Android System Webview
* Lowered bootanimation fps from 25fps to 20fps
Changelog For v3.1:
* Removed Google Search to save storage space
* Fixed Random Wi-Fi Disconnections/Disables after restarting your device
* Updated Gmail
Changelog For v3.0:
* Updated Jelly Browser to v1.1 we added added assets and flash to the browser.
* Updated Fingerprint in flasher
* New Browser Icon from GamerROM 8™
* Browser now doesnt require you to allow for location and will automatically locate your position, however will only ask to allow location if you or website asks/requires it for persise locationing
Changelog For v2.6:
* Improvments to System Performance
* Removed FPS Cap this can help in games supporting 1080p 60fps or higher
* Disabled Logcat by default to improve battery life
* Set ART ISA to div instead of defsult
* Added GSM version to this build for Google Play Services
* Updated Gmail
* Improved System Stability
Changelog For v2.5:
* New Kernel Implemented with new Governors etc features
* Set SELinux to Permissive
* Removed bootanimation.zip to save on boot times & menory usage
* Removed CMFileManager & CMUpdater from this build
* Removed Screencast as it only recorded video for only 0:42 seconds and picture was aweful
Changelog For v2.3:
* Removed the ASOP Webview v52 and replaced it with Google Android System Webview v60 this will increase load up times within apps that loads webpages.
* Updated Google Search app
* Now the OS is now in it's BETA Phase
Changelog For v2.2:
* New Browser is the Samsung Internet Browser
* New Pixel Launcher
* Improved App Emulation when playing emulators
Changelog For v2.1:
* New Browser this fixes typing bug when you type in the browser you had to tap another part of the feild or outsude of the field, however the browser icon doesnt show up in the launcher dock you have to manually drag it their until i figure the browser issue
Changelog For v2.0:
* Upgraded entire OS to Android Version v7.1.0 Nougat
* No Setup Wizard as we are having issues with it so setting up the phone is more work for you sorry
* Fixed Wi-Fi bug no more wifi or cellular data will disconnect
* OS now only support jfltetmo
Changelog For v1.0.4 (Minor Update):
* New Browser and new Icon (fixes webpage and browser crashing when visiting None Mobile Websites)
Changelog For v1.0.3:
* Fixed Wi-Fi Connectivity Bug that always disconnected from the network
* Reverted Launcher & Browser Back to the Old Ones
* Removed the Model setup in the installer but is able to install on many models but model name will be locked to SGH-M919 you can change the model using a build prop app
* Fixed SDCard Reading issue that caused the OS to think the EXT Sdcard was currupt and after attempting setting up, will still says its corrupted
* Added Sdcard R/W Permissions to platform.xml
* Improved Cooling with the CPU/GPU, however heat can still arise while playing or using high cpu/gpu usage applications
Changelog For v1.0.1:
* Replaced the Old Launcher with Google Now Launcher
* Fixed Issue with Browser by reppacing it with Google Chrome (may change on a future update)
* Fixed Bug that prevented OS to boot up or even pass the S4 banner
* Now Supports all models
* Improved System Performance & Security
Notice: Their is no setup wizard in this build as it kept asking to transfer via NFC and not continue if you cannot do it!
