Valculator: Voice calculator
smsm1991
Poster
Description
Valculator is Voice Calculator for android phones,
So if you have android now you can calculate your voice
This app performs your calculations easily by your voice!
You just speak your calculations to it,
and it will get them out! You just Say "1209 + 33 - 8",
and the app will show you the
answer "1234"!
Think about the situations when you need such a tool!
How much do you need to calculate something?
The keyboard numbers entering method is time
consuming and very boring, isn't it? You may need reading
glasses, and (like always) you forgot to bring it with you.
So You need not to use keyboard! Do you need
to use a quick and easy-to-use calculator
with your study/work? Then, meet Valculator.
Screen Shots
Now you can install it to your android phone from Here
Install now
