Variables %SCREEN and %WIFI always SET?
Plecto123
How come the variables %SCREEN and %WIFI are always SET regardless of whether the screen is on/off or the wifi on/off? I've got a Huawei Honor 5x and Android 5.1.1
Seems like the variables store "on" and "off", having %SCREEN eq off, and %SCREEN eq on, instead of SET/!SET worked :)
eq works fine for me, but whats the difference between equals and matches? Also, when is a variable !SET? When its completely empty?
Matches - look up pattern matching ... in this case they both work and are case sensitive.
%SCREEN is always set to on or off. Try ...
Task
A1: Flash [ Text:Set Long:Off ] If [ %SCREEN Set ]
A2: Flash [ Text:!Set Long:Off ] If [ %SCREEN !Set ]
A3: Flash [ Text:~ on Long:Off ] If [ %SCREEN ~ on ]
A4: Flash [ Text:eq on Long:Off ] If [ %SCREEN eq on ]
A5: Flash [ Text:~ ON Long:Off ] If [ %SCREEN ~ ON ]
A6: Flash [ Text:eq ON Long:Off ] If [ %SCREEN eq ON ]
... Thom
I use equals when comparing numbers or numerical expressions and matches when comparing strings (including pattern matching as Thom mentioned)
Built in variables are always set.
User variables are set at the time you assign thenm a value. (I'm not sure if there's a way to create an uninitialzed variable except perhaps to reference a variable name that hasn't been assigned a value... never comes up in anything I do. I'm sure it has some purpose for advanced users, but not for me and I'd venture to say not for most beginner/intermediate tasker users.
So in summary the variables I work with are always set and I don't ever find a need to test if a variable is set... test the value with eq or matches instead.
