Root [Verizon] anyone figure out usb mount???
mlee19841
Member
anyone figure out how to get usb mount for the s3 for Verizon. Im looking to purchase one within a day or 2 and just wanted to make sure if i hook my phone up to the comp. will it let me copy files over like things used to be?? Don't want to have to set up some type of server and do it that way just want to plug and go.... thanks for any feedback it will make my purchase that much easier......
Are you asking if you can connect your phone to your computer via USB and transfer files? If so, the answer is yes. You can also connect a USB drive to your phone and transfer files that way.
You can transfer files via USB connection; however it does not mount its storage as an external drive as in pre-ICS (its a google design, not specific to the phone).
It is better in that you don't have to manually mount/unmount and screw up apps. It is worse in that you don't have full access to storage without third-party software (like Droid Explorer).
