Brandon8427
Is there any way to use a Verizon smartphone without having it activated? Could you root it or something?
First off, I moved this thread into the Verizon forum
Next off, yes you can use your device even if it isn't activated on Verizon, you do not need to root it or anything, if the device uses 4G however, be careful to never turn it on because it might accidentally register the device back to your account, however, as far as i know the device won't even receive signal so the only thing you could use it for is a Wifi device.
