ironass
Extreme Android User
At one time, the Google Nexus phones were the ideal models to get in the U.S.A. as they came with unlocked bootloaders, no bloatware and updates direct from Google. Well, all that has changed if you get your Pixel model from Verizon or Best Buy....
"This means that Google will still push security updates to all Pixel (XL) phones including those on Verizon, while significant software updates which change the version number, will be released by Verizon on Pixel phones bought through the carrier or at Best Buy (as Best Buy only sells the Verizon-locked version). As a reminder, the Verizon Pixel phones will not come with an unlockable bootloader."
"if you want to avoid Verizon holding updates hostage, you can totally pre-order the unlocked version from the Google Store, as it works with all major carriers in the US, including Verizon. The Google Store even offers 24-month no-interest financing options."
See the GSMArena article... Verizon to manage Android updates to Pixel phones it sells
You have been warned!!!
