Root [Verizon] Question regarding "Fast Charge" setting
dkl1
Android Expert
I use the 'fast charge' setting during the day and 'normal' setting overnight. I sometimes forget to change the fast charge to normal before going to bed adn leaving the device on the charger all night. Does this do any harm to *anything*?
I am running the Zeus Kernel v5 w/Pegasus/cfq
Thanks :smokingsomb:
Nice!!
You don't need to use the fast charge when using a wall charger.
The fastcharge is for USB ports to fool it into thinking that the phone is plugged into the wall. It will allow the full 1 amp charge when plugged into the computer.
When fastcharge is enabled, your files will not be accessible on the computer...just keep that in mind.
Does that make sense? :D
Nice!!
That makes 'poyfect' sense! :p
I didn't know that it is made to be used with a usb connection on the PC... hmmmm! Thank you Sir :p:beer:
