Root [Verizon] Recovery and charging problem/question
durarian
Member
I rooted and installed EZrecovery last night, I used the CWM 6.0.1.0 recovery option since it has Key-exec. I then installed beans custom stock rom.
My issue is, normally I turn my phone off at night and charge it, however when turning the phone off and charging it, it gets stuck in this loop that it is attempting to turn on and vibrate, but turns off and just repeats that cycle constantly. Is this a key exec thing or perhaps just an issue with the recovery? Or is thre something I messed up? It flashed just fine and everything works great...just curious about that.
Thank you!
Sounds like it's the kexec. Don't turn your phone off at night, it's not necessary. You can use an app to set-up custom alert profiles to silence what you don't want at night.
