Is anyone else having difficulty using svoice on the Verizon gs3. the simple task will work, but when i try the example questions such as "how high is mount everest", it reverts back to say hi galaxy to wake me up. i already cleared data from app manager? any ideas?
Can we turn it off? Where is the setting for S-voice? I couldn't figure it out at the verizon store today.
Also I saw AC article on how to disable "double tapping home button for s-voice" for faster button response but couldn't find how to do it.
How can I use google voice search instead. I've been using it for 2 years on my DX and it always does exactly what I want and I'm fine with it as is until they improve s-voice or google improves their own in Jellybean.
I just disabled it in the Application Manager.
Thanks. I found that AC article below. But it looks like international GS3. Does this setting exist in US version?
Samsung Galaxy S III tip: disable S Voice for better home button response | Android Central
its in google play
Yea yea. I know there's an app. That's not what I'm asking for. I'm talking about the voice control you get from *any* android phone when you do a long press of the search button and the voice digitizer comes up *REGARDLESS* of where you are or what app you already have up.
There is no search button button this phone. Instead of 4 buttons, there are 3 and that one is gone. I'm assuming that there's some way to activate googles stock voice search from a long press of some button or something. If not, then the phones will go back before I even activate them because I use that feature dozens of times every day while driving.
I haven't activatd my S3s yet(waiting for cases to arrive today) so I'm not sure. It's the global stock google voice search on any andriod. The on that regardless of what app your in, you can always press the search button and say something like "navigate to <destination>", "map of <location>", "call <contact>", "goto <website>", etc.
It may be simple, but it works for me 99 percent of the time and even does so if the screen is off and I'm in the car driving at night. I don't have to look at the screen to use the feature. I just press the search button and hold it for 2 or 3 seconds.
Yeah the first day I had mine it was answering all kinds of questions. Now those questions revert it to "hi galaxy" :/Is anyone else having difficulty using svoice on the Verizon gs3. the simple task will work, but when i try the example questions such as "how high is mount everest", it reverts back to say hi galaxy to wake me up. i already cleared data from app manager? any ideas?
Hmmm I'm in PA and mine isn't working rightKen7, are you anywher near PA or OH? And are you using Verizon? If this is a server issue, I wonder whether it is more of a regional problem.
