Root [Verizon] Some SystemUI tweaks
rehpyc
I've made a few different tweaks to my notification bar and dropdown menu, if any of you would like them for yourself. I've removed the E911 service icon that shows up to the left of the wifi symbol and the battery image bar that stays to the right of the battery percentage.
I've also taken the great work from xCaldazar over at XDA, who made a lot of modifications to the pulldown bar, and altered the toggles to be only the ones I use. The toggles and order thereof can be customized.
Below are the images of my setup w/o the E911 icon, battery bar, and pulldown menu. Attached is the SystemUI.apk that you can use to replace your current - a reboot will be needed after you make the replacement.
