GreenMan62
I rooted my device using Odin and it is completely stock JB. I was using ROM Toolbox to change boot animations. I downloaded the 2 zips...CWM_CustimBootAnimation_Disable and CWM_CustimBootAnimation_Enable. It worked at first but when I was trying to figure out how to change the boot animation to a different one I couldn't figure out how to do it and that is where I think I messed up. I have bootanimation.zip in system/media with rw-r--r-- permissions and bootanimation.zip in data/local with rwxr-xr-x permission settings. When I enable CustomBootAnimation in CW it boots with a black screen and the screen never turns on. When I disable it, obvioulsy it boots normally and everything is ok. Sometimes it will boot up normally, turn black when the boot animation should be, but then return to normal when CustimBootAnimation is enables. I'm not sure what I'm doing there to make that happen. My question is, what am I doing wrong and how can I get my custom boot animations working again? Thank you in advance.
