MicroMod777
I've modified some previous scripts to automate rooting and twrp. Special credits to the original creators of the apps who've I've modified. Can't remember who they are.
Step 1: Go to Settings, About, Software information, and tap Build Number like 6 times to unlock developer options.
Step 2: Plug in USB cable to computer, check Internet connection, Ethernet
Step 3: Go to Settings, Developer options, and check USB debugging. Wait for pop-up and Allow USB debugging.
Step 4: Run your one click options downloaded.
Download for Windows: Tested on Windows 7 64bit. Probably works on others.
ROOT
One Click Root, 10b, 11a, 12b ota's. Follow steps on screen.
http://bit.ly/P5Bv2C
One Click Root for 24a, ioroot25:
http://forum.xda-developers.com/showpost.php?p=48709232&postcount=869&nocache=1&z=7334539103321731
RECOVERY
One Click custom recovery TWRP for 12b ota. If your on 11a, do OTA first. Must have root also.
http://bit.ly/1jL99WB
Then flash this in recovery if you wants TWRP 2.7: Thanks MindRocket
http://bit.ly/1gHz80Q
ROOT
RECOVERY
