What is the code you press again to update radios for Verizon Wireless?
D DoctorEyeSight Android Enthusiast Feb 25, 2012 302 8 Jun 25, 2012 #1 Jun 25, 2012 Add bookmark #1 What is the code you press again to update radios for Verizon Wireless?
trophynuts Extreme Android User Jul 6, 2010 5,629 1,792 SouthEastern US Jun 25, 2012 #2 Jun 25, 2012 Add bookmark #2 Create a contact called PRL update, for the number you use *22899, once the contact is created call it. fwiw This is the number to dial to update the PRL , you're not updating the radio. Upvote 0
Q quickaudi Android Expert Jul 15, 2010 3,106 416 TN Jun 25, 2012 #3 Jun 25, 2012 Add bookmark #3 and it's not really needed with our SIM card, because it updates automatically Reactions: jkc120 and Crashumbc Upvote 0
