I'm suffering from weird behavior from my SGS, I really dunno what's happening.
I have Samsung i9000 galaxy S. It's from Saudi Arabia, working fine with me for about 5 months now. the phone had Froyo, I flashed it with the same ROM (don't remember why), then I rooted it, and it was great for 4 months. My Rom now is 2.2.1, baseband I9000JXJPF , Kernel 2.6.32.9 root@SE-S606 #30
build number FROYO.JPJPM
few days ago, I've set the alarm for work as usual, then it didn't ring, I then knew the phone screen was black and it was dead but the 2 buttons around the home button get their lights on when you touch them. I had to take out the battery then back and turn on, to find the following changes !! :
-all contacts deleted, and SIM contacts are displayed (i use google contacts)
-logs empty
-all SMS deleted
-haptic feedback enabled, auto rotation enabled, GPS enabled (they were not)
-Home button not working at all in any situation (even for task manager)
-EVERYONE who calls me is auto rejected, but appears on my log !!! while auto rejection settings are disabled...
-when you click Power button for a while, the Phone option that appear is only "Phone Off", so the Flight mode,Data network and [something else i don't remember], all have disappeared
-my APNs are deleted
-every now and then, the phone suddenly says that external SD was removed unexpectedly...
ofcourse there might be other things that I couldn't notice.
I reset to factory settings and started all over and put some applications again, and it worked fine for 1 day then all that happened again. then to factory again but didn't install any apps, I just synced my gmail contacts and changed some settings and that's it, and it happend in like half a day......
So I knew going to factory is not a solution, so I flashed the phone with the same ROM but haven't rooted it. At this point I was very happy and thought everything was solved. Untill it happened with me NOW.....AGAIN only after 2 days from the flashing
It looks like it's not from an App, because it happened even when i didn't install any apps after the 2nd factory reset.
Can it be Hardware
or Maybe a virus ?
should I format all storages then flash ?
Please help, my phone is new and can't receive any calls till I fix this.
Thank youuu
-logs empty
-all SMS deleted
(It looks like it's not from an App, because it happened even when i didn't install any apps after the 2nd factory reset.
Can it be Hardware
(( ?or Maybe a virus ?
Thank youuu
