[GUIDE] Viber on Nexus 7
Hi guys , i started a thread on how to get Viber on your nexus 7.On the Play Store page on the Viber it says :
" What's in this version:
v2.2.1:
* Support for Jelly Bean (android 4.1)
* Bug fixes and improvements
Thank you all for your feedback. " but it you can't run it on the N7 . Its very easy . So :
1. Download it
2. Open it with ES File Explorer
And now the problem comes : You cannot use your viber account on your phone and on your N7 / tablet , so you will have to send the validation code ( or something like that ) to another phone number ( *YOUR CHOICE* )
3.Run it
And you are ready . I use it for more than 2 days and it runs perfectly smooth . Take a look at it .
https://play.google.com/store/apps/details?id=com.viber.voip&feature=nav_result
And.......If i helped you please click the THANKS BUTTON
v2.2.1:
1. Download it
3.Run it
