Help Vibrate function not working
jeff84
Hey..
Having a problem when I'm setting my phone to the vibrate function. It doesn't vibrate at all, just acts as if I set the phone to silent.
How do I fix this? Anyone else have this issue since the rogers update. My gf is having the same problem with her X10.
Thanks
For Messages: go into messages on ur home screen, while there push the left key and click settings. scroll to the bottom and u will see vibrate. make sure it is checked
For calls: at the home screen, click the left most button and click settings. go to sound and display and make sure u have vibrate checked.
If they are all checked uncheck them and then recheck them. hopefully that works
