daffy113
Vibrate not working on incoming calls or texts
My phone is rooted using the Odin and Root66 method.
I have Verizon 32 GB model.
Everything is great except one incredibly annoying feature.
My phone won't vibrate on incoming calls or text. I know vibration works because when i go into:
Settings > Sound > Vibration Intensity is set to high for Incoming, Notification and Haptic.
Silent mode is set to Vibrate.
I've read various articles and this is the only area I've been told to check. My father has the same phone which I rooted in the same way and his vibrate works on calls with the same settings.
Do you think that something in the rooting disabled it on the backend.
