Good evening!
I know that the Samsung VIbrant uses the 3.5 mm jack as the video out but I am wondering if it can also do video out through the micro USB as well?
I see that there is a micro USB to HDMI cable in ther works, but my dilema is this....
I just got a new head unit in my car which I would like to connect my Vibrant to in order to play video. I installed a iPod input so I can use it, but was wondering if I could find a micro USB to iPod (female) cable (or have on custom made...woudl this work. Similarly, I could also use the 3.5mm jack, but that would require a cable which I do not think exists?! Trying to find or have one of those made too?
Basically, my question is simple....does the usb out also carry a video signal?
Secondly, does anyone know of a cable which would carry video from 3.5mm to a femal iPod, and not just audio??
Thanks in advance for any help / advice.
