Video recording - Slow start problem
bennee7
Hey there, is anybody experiencing serious lags when trying to start recording video through Camera app? Sometimes it takes almost 10s, very often around 3-4s... it's extremely annoying especially when trying to catch a quick moment. Does anyone have any clue how to fix this? System updated, all apps updated as well. Thanks for any serious tips 😊
Cuz I have the us version(snap) and have no such issues...works smoothly right after pressing record
Cuz I have the snap version (us variant) and am not experiencing any such problems
EMEA, so most probably exonys, you think that might be a problem? It's supposed to be fast enough for such simple operation... for example, multiwindow with any content works like a charm...
I don't think it's because it's exynos since the exynos is supposed to be the better performer....try doing a factory reset...maybe that will help...I myself am suffering from some issues such as the micro lag when exiting applications(does not close smoothly like if u compare with any other smooth Android phone)
Thanks for input! However factory reset is my last option if ever...
If there is anyone with any other advice, please go ahead and post it.
If u still have that problem ...then I think it will better for u to have the phone replaced if it is still under warranty that is
