Viewing tasks/reminders...not using defauklt Calendar
carnut65
Just tried S Voice to set a task/reminder and find that it places the task only in the default calendar app which I prefer not to use. Prefer to be able to 'manage' tasks outside of any calendar or have them appear in TouchDown (MS Exchange) calendar. Any thoughts?
Similar threads turned up 'Astrid' or now 'Tasks' app. Any feedback on this?.....thx
Have you tried something like
"Run TouchDown"
"Press New"
"Set Date 7-3-2014"
"Enter Go Shopping"
"Enter Item Hot Dogs"
Or whatever the sequence of events in TouchDown would be? (I seldom use voice for anything but search in Maps, and I never use TouchDown, so I don't know whether it would work, or do anything at all, but it'll take you 5 seconds to see if anything happens. If it does, it may take you a while to figure out exactly how to phrase the commands.)
no good. Will only get as far as activating TD. Also, just heard back from TD tech-suppt to which they confirmed the app doesn't support two-way synch for security reasons....thx
