All i am doing is ; ive d/loaded Htc sync, then ive got the full version of vignette,ive taken some pics but i cant seem to save them to a gallery or any other folder(just vignette) so htc sync dosnt recognise it and i cant copy or paste the pic to another folder which i can use on my pc,Can they be viewed using a file explorer Astro or ES File Explorer.
When syncing, are you trying with the Standard HTC Sync App? Have you tried mounting as a USB Device and copying via windows explorer?
Alternatively, there's an app called MyPhoneExplorer which is a pretty good sync solution and you don't need to be connected via a USB cable, it can be done over WiFi.
Excellent it worked,,,,ThanksTake HTC Sync out of the equation. If they're saving to a folder on your SD Card, the folder they are stored in should be viewable when you mount your phone as a USB Drive to your PC?
