Vignette is not saving the pictures I take, please help!!!
Chrupti
Hi there,
I bought the new version of Vignette ages ago and it's always worked fine, until yesterday. There was an update available that I automatically downloaded and since then none of the pictures I've taken has been saved (I was using Random from all effects) - When I do take a picture it shows me the preview and it says that the picture is being processed but when I go into Gallery I can only see a thin white line instead of the actual picture I've taken:(
I tried taking pictures with different effects but nothing has worked. Can you please help? I love Vignette and I'm desperate if I can't use it!!
Is there any way I can cancel the update from yesterday as the problems started then?
Thanks a lot
