Figured we needed a thread dedicated to battery life, replacement battery options, kernel tweaks, etc., in order to not derail other threads. Please feel free to post here anything related to batteries or kernels, including ROM-specific issues.
Under the built-in ROM features, at Settings/Performance, I use the Performance Profile, with Purging of Assets and Kernel Samepage Merging enabled under Memory Management.
I'm debating whether or not to enable KSM. Have you seen a noticeable difference?
What about voltages?? ⚡⚡⚡
liquid smooth dkp kernal interactive gov..its good but i need slightly better battery life
what about performance is freelauch better than iinteractive
What benefits are gained by bumping up the Read Ahead Buffer Size?
Is it OK to flash a kernel on a stock ROM then flash back to CM11? Just wanna make sure that CM11 won't screw with the kernel. I'm on CM11 right now. Would have to flash back to stock to flash a kernel but if it would help I'd definitely do it. Just need the info first. Thanks for any help.
Any time you flash a custom kernel, if you then dirty flash a new nightly or change ROM's altogether, the custom kernel will be overwritten by the kernel that is built into whatever ROM you most recently flashed. Also, kernels for TW based ROM's are vastly different from kernels built for AOSP, you can't interchange the two. So, if you intend to flash a custom kernel, make a Nandroid right before, that way if you don't like the custom kernel, you just restore your most recent backup and the custom kernel will be gone.
Any good kernels that work with CM11?
As far as I'm concerned, it's always dkp kernel for the win, on any AOSP ROM. Leankernel is a close second.
Download page for dkp kernel (AOSP versions)
Download page for Leankernel, unified build version (choose 9.5.1)
Thanks bro. Thanks button is hit.
I can't believe that I haven't browsed some of the other carrier forums on XDA for the SGS3 until tonight to look for more d2lte/unified options that don't have threads in the Sprint forum. Found several ROMs, either new to us or updated versions of what is available on the Sprint forum, along with a new kernel. The kernel is from Quantum ROM; the ROM does flash, but being closely based on CM11 does have the current data connectivity issues (for me, LTE connects but 3G refuses). However, the kernel is available as a separate download, so I have flashed that on latest LiquidSmooth, will let it run for a while and see what happens.
