Root [Virgin Mobile] Correct updated way to revert to stock?
Photonik
I'm looking for a correct, updated way to revert to stock for our virgin mobile SPH-L710's. I've done a little googling but there doesn't seem to be updated stock roms specifically for our carrier. Is it as simple as running triangleaway then going with a stock rom like something seen here:
http://forum.xda-developers.com/showthread.php?t=2755793
Or is the fact that that's a Sprint rom somehow an issue? I tried reverting to stock through Kies but it won't accept my IMEI to allow me to begin the process.
Thanks, will this also revert my recovery to stock? I'm having EFS issues and I've read that sometimes taking an update through Kies will fix it so I'm trying to get my phone to a state that kies will automatically recognize it and push an update through.
Yes that will tale you to complete stock, even recovery. But check your build and baseband in about phone. If it ends in nj3, don't do it. If its NDC or earlier, good to go. Flash it with Odin.
