Root [Virgin Mobile] Galaxy jams and restarts
jrccomputer
My gs3 keeps jamming than it restarts. It does this when I open an app. And its not just one app it could be any of them. This is happening since I rooted and since I deleted some of the bloat. Is there anyway I screwed my device?? Is there an stock so I can unroot my phone and get back to original device???
You probably deleted a required apk. You can try to boot to recovery and wipe dalvik and cache then boot.
Oh and also fix permissions in recovery
I haven't removed s voice, but I heard others say that they removed it, plus the others are safe to remove, so who knows... Do try ryders ROM though it's working good.
I haven't remove s voices, but the others are safe to remove... Try riders ROM though it's working good.
Yeah. So an example of a jam is with the phone/dialer. I dial 611 hit call. I get a black screen. The phone is then unresponsive. Then after awhile it restarts.
Get you app back in first the keis file is a no data file!!
You mite want to use mobile odin if you stay rooted!!
Ok. Went through all these steps for no reason. The dial wont dial 611 without the my account app.
The apps I deleted are as follows: s voice (hate the double tap), my account, help, and mobile id.
