Does anybody happen to know what is causing the problem with LTE in the CM builds, to at least narrow it down?
It's a sprint ROM. 4.2.2Where did you find that Pacman Rom? Is it a ported Sprint ROM or specifically designed for the Virgin Mobile version?
I am currently running Pacman Rom witch is CM/AOKP/PA based and have working 4G. I'm Pretty sure all your 4g issues are APN based. The link ENVi3 posted has a fix. I could upload a .xml for APN backup and restore if anyone wants it.
Wait... so you have LTE and MMS working together ;o because when I change the apns I only can get either or :/ I'm running cm10.2.
Where are you changing the APNs from? ##data#?
