So I had this problem. And the solution is simple... this is how I got my data working ...and yes this includes both LTE and 3G
1. Go to your custom recovery and preform a factory reset, and wipe the delvik cache.
2. Flash the CM 11 rom and the Gapps.
3. Reboot the phone and then turn it off and go back to the recovery.
4. Flash the zip I provided AND NOTE THAT THIS IS NOT MY FILE! I DO NOT CLAIM ANY CREDIT OTHER THAN HELPING YOU OUT, BUT THE FILE IS NOT MINE. Now you just have to reboot your phone and depending whether you have a good cell coverage or not you should have your data working!
