Root [Virgin Mobile] MOAR 4.3 for d2vmu?
What steps are involved to porting this MOAR ROM to our S3?
[ROM][MOAR][MK3] v8.0 / 30+ Mods / Theme on the fly / Floating Multiwindow [01.27.14] - xda-developers
I am familiar with removing assert lines and flashing MMS fix, but what about flashing the modem? What modem do we flash for this?
I'm curious to try this ROM.
TouchWiz ROM's are ready to go straight out of the box, you just need to flash the appropriate APN fix. Assert lines in the updater-script are a feature of AOSP ROM's, and are therefore not present in MOAR, Wicked Sensations, or any of the other TW based ROM's. As far as modem, the recommendation on their XDA thread is for MK3 because they are catering to the Sprint crowd; you can use that modem if you want, but MK5 works perfectly fine.
My fixes were made for CM / AOSP ROMs. That said it may work with TW based. Flash the ROM first. On first boot check (navigate) to see if it has:
/dev/block/platform/msm_sdcc.1/by-name/system
and
/dev/block/platform/msm_sdcc.1/by-name/userdata
If it does - it will install correctly
and
You should consider adding this info to your post for the APN fix.
