Root [Virgin Mobile] Paranoid Android successfully running?
This is the link you need: Paranoid Android Legacy d2lte. The link you posted was for the international version of the Samsung Galaxy S3. This link is for any US variant of the GS3. I'm running it now, so I can confirm it works. It's Android 4.4.4. The 4.5 Beta1 build incorporates the Android L stack recent apps panel.
Here's a list of other Android 4.4.4 ROMs: Android 4.4.4 ROMs. I'm just posting this also because the Android 4.4.4 GAPPS and the APN settings fix you'll need to get the data working are both in this list as well. And plus I'm feeling a bit exhausted right now and posting one link seemed easier than 2.
I just began running Paranoid Android Legacy, and was wondering if theres any way to change my lock screen wallpaper that you've encountered.
I don't think there are settings with this ROM that will let you. But if you're running GravityBox with Xposed Frameworks, you can through the Lockscreen Settings. GravityBox also lets you change a lot of other features of your phone also.
