![fa4j8g.jpg](http://i58.tinypic.com/fa4j8g.jpg)
____________________________________________________________________________________
This is a port of the legendary rom Conquest by moonknightus. It is based off of 11.3/Cataclysm and is made to work on ND4 baseband, along with some of my added tweaks.
Code:
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
DEVELOPMENT CEASED
Original Features:
- Based on deodexed ND4 stock ROM
- Busybox pre-installed
- Rooted with SuperSU
- User-selectable launcher
- AOSP style Holo Blue default theme
- Custom Boot Animation
- Customizable notification drawer toggles
- Removed headphone/audio app notification and battery full notification
- TouchWiz Messaging app notifications disabled and icon hidden from app drawer by default
- Activation and Sprint Connection Optimizer removed
- Call reject list enabled in phone settings
- Removed wake command from lock screen options
- Water and ink effect options for TouchWiz lock screen
- 360-degree screen rotation enabled
Added Features:
- Added battery tweaks to init.d
- Added ram scripts to init.d
- Added entropy scripts
- Added OTA update support for rom
Install Instructions:
Full Versions:
- Reboot into recovery
- Wipe /system, cache, dalvik, and factory reset (recommended)
- Flash and reboot
Updates:
- Wipe cache and dalvik
- Flash and reboot
Alternatively, you could open the OTA Updater app and install updates and full roms from there.
[___________________________________________________________________________________
Downloads:
Roms and Updates:
Download Beta 1 here
MD5: 5092b3109e2f658f4c6ca73cbb5c8c17
Themes:
Themes can be found at this link.
Contributors:
Nick_73, moonknightus, Insanelycool, the_Victorian
Rom OS version: Android 4.1.2 Jellybean
Rom kernel: Linux 3.0.x Insanelycool Kernel
Based on: Conquest Cataclysm
Version Information
Status: Beta
Created 01-28-2015
Last updated 01-29-2015
