virtual devices not working in android studio
hello in android studio not working virtual devices say error "The emulator process for AVD sfdhfhdsh has terminated" and others apps where too have android virtual devices android sdk connected and virtual on in my pc bios can who help
Any more error message or screenshot? Is your AVD based on Intel x86 CPU?
Presumably your PC supports Intel VT? Check you've actually got Intel Virtualization enabled. I'm not a dev, but I believe Android Studioi requires hardware virtualization support in order to run virtual devices to simulate hardware for development.
Can you successfully start that AVD sfdhfhdsh in AVD Manager? Would you like to show us the details of this AVD?
forgot details here details
CPU/ABI: Intel Atom (x86_64)
Path: C:\Users\Иван\.android\avd\sfdhfhdsh.avd
Target: default [Default Android System Image] (API level 27)
SD Card: 512 MB
runtime.network.speed: full
test.monitorAdb: 0
hw.accelerometer: yes
hw.displayRegion.0.3.yOffset: -1
hw.display1.xOffset: -1
hw.useext4: yes
kernel.newDeviceNaming: autodetect
disk.systemPartition.size: 0
hw.initialOrientation: portrait
hw.sensors.light: yes
hw.sensor.roll.resize_to_displayRegion.0.2_at_posture: 6
hw.displayRegion.0.1.width: 0
hw.display2.yOffset: -1
hw.display3.flag: 0
hw.ramSize: 1024
fastboot.forceColdBoot: no
hw.gltransport: pipe
hw.displayRegion.0.1.xOffset: -1
hw.sensors.proximity: yes
hw.sensors.gyroscope_uncalibrated: yes
hw.dPad: no
hw.lcd.height: 1280
vm.heapSize: 112M
hw.device.manufacturer: Google
hw.sensor.roll.resize_to_displayRegion.0.3_at_posture: 6
hw.displayRegion.0.3.width: 0
hw.display1.density: 0
hw.gltransport.asg.writeStepSize: 4096
hw.gps: yes
hw.lcd.vsync: 60
hw.keyboard.lid: yes
hw.sensor.hinge.fold_to_displayRegion.0.1_at_posture: 1
hw.sensors.temperature: yes
hw.display2.flag: 0
showDeviceFrame: yes
hw.resizable.configs: phone-0-1080-2340-420, unfolded-1-1768-2208-420, tablet-2-1920-1200-240, desktop-3-1920-1080-160
hw.camera.back: emulated
hw.sensor.roll.count: 0
hw.gltransport.drawFlushInterval: 800
hw.gsmModem: yes
hw.sensor.roll.resize_to_displayRegion.0.1_at_posture: 6
hw.device.hash2: MD5:d37b758e1a2b070e348378c2efde849a
fastboot.forceChosenSnapshotBoot: no
hw.display1.height: 0
hw.battery: yes
hw.sdCard: yes
tag.display: Default Android System Image
runtime.network.latency: none
hw.sensors.magnetic_field_uncalibrated: yes
hw.sensors.pressure: yes
hw.display3.yOffset: -1
hw.gpu.enabled: no
hw.display2.density: 0
hw.displayRegion.0.3.height: 0
hw.device.name: Galaxy Nexus
hw.display3.xOffset: -1
hw.displayRegion.0.1.height: 0
hw.displayRegion.0.2.height: 0
hw.keyboard.charmap: qwerty2
hw.lcd.width: 720
test.delayAdbTillBootComplete: 0
hw.displayRegion.0.1.yOffset: -1
hw.rotaryInput: no
image.androidVersion.api: 27
kernel.supportsYaffs2: autodetect
hw.screen: multi-touch
tag.id: default
hw.display1.width: 0
avd.name: <build>
test.quitAfterBootTimeOut: -1
hw.audioOutput: yes
hw.sensor.roll: no
hw.mainKeys: no
hw.displayRegion.0.2.width: 0
hw.displayRegion.0.3.xOffset: -1
hw.camera.front: none
hw.sensors.humidity: yes
avd.id: <build>
hw.gpu.mode: auto
hw.display2.height: 0
hw.sensor.hinge.count: 0
PlayStore.enabled: no
hw.cpu.ncore: 4
hw.keyboard: no
disk.cachePartition: yes
hw.sensor.hinge.sub_type: 0
hw.display2.width: 0
hw.displayRegion.0.2.yOffset: -1
hw.gltransport.asg.dataRingSize: 32768
hw.sensors.rgbclight: no
hw.display2.xOffset: -1
hw.sensors.heart_rate: no
hw.audioInput: yes
image.sysdir.1: system-images\android-27\default\x86_64\
hw.sensor.hinge: yes
hw.display3.density: 0
disk.dataPartition.path: <temp>
hw.gltransport.asg.writeBufferSize: 1048576
hw.display1.yOffset: -1
hw.display3.width: 0
hw.lcd.density: 320
hw.arc.autologin: no
hw.sensor.hinge.type: 0
hw.arc: no
hw.display3.height: 0
hw.sensors.magnetic_field: yes
fastboot.forceFastBoot: yes
hw.lcd.backlight: yes
hw.displayRegion.0.2.xOffset: -1
hw.trackBall: no
hw.display1.flag: 0
disk.vendorPartition.size: 0
hw.gyroscope: yes
disk.cachePartition.size: 66MB
disk.dataPartition.size: 800M
hw.sensors.orientation: yes
hw.lcd.depth: 16
avd.ini.encoding: UTF-8
SD Card: 512 MB
test.monitorAdb: 0
hw.useext4: yes
hw.display3.flag: 0
hw.ramSize: 1024
hw.dPad: no
hw.lcd.height: 1280
vm.heapSize: 112M
hw.gps: yes
hw.lcd.vsync: 60
hw.display2.flag: 0
hw.gsmModem: yes
hw.battery: yes
hw.sdCard: yes
hw.gpu.enabled: no
hw.lcd.width: 720
hw.rotaryInput: no
tag.id: default
avd.name: <build>
hw.audioOutput: yes
hw.sensor.roll: no
hw.mainKeys: no
avd.id: <build>
hw.gpu.mode: auto
hw.cpu.ncore: 4
hw.keyboard: no
hw.audioInput: yes
hw.lcd.density: 320
hw.arc: no
hw.trackBall: no
hw.display1.flag: 0
hw.gyroscope: yes
hw.lcd.depth: 16
It seems that the Target option is error. The default system image, API level 27, doesn't seem to be installed.
Change it, and then try again.
[QUOTE = "James_Watson, post: 8054411, member: 1776497"] Похоже, что параметр Target является ошибкой. Образ системы по умолчанию, уровень API 27, похоже, не установлен.
Измените его и попробуйте еще раз. [/ QUOTE]
оk
its installed
Okay, I see. This issue may be caused by improper SDK location.
In Android Studio, go to menu 'Tools - SDK Manager',
Or 'File - Settings - Appearance & Behavior - System Setting - Android SDK'.
Click 'Edit' besides 'Android SDK Location'. Set your proper Android SDK Location here.
If this will not work yet, restart your computer, and then try again.
If it helps you, please give me a small favor.
[QUOTE = "James_Watson, post: 8054463, member: 1776497"] Хорошо, понятно. Эта проблема может быть вызвана неправильным расположением SDK.
В Android Studio перейдите в меню «Инструменты - Диспетчер SDK»,
Или «Файл - Настройки - Внешний вид и поведение - Системные настройки - Android SDK».
Нажмите "Изменить" рядом с "Местоположение Android SDK". Задайте здесь правильное местоположение Android SDK.
Если это пока не сработает, перезагрузите компьютер и попробуйте еще раз. [/ QUOTE] does not work, okay, I'll run it through the browser
