VissonTech ATV-102s / Tronsmart Prometheus firmware
stane1983
Hi folks,
On www.stane1983.com under Downloads you can find latest firmware for device mentioned.
Features:
  • Kernel 3.0.101
  • Android 4.2.2, based on latest Amlogic sources (2013-12-25)
  • Windows 8 UI, makes navigating easier
  • Wifi works on older and new devices (Visson changed wifi module)
  • Rooted (CyanogenMod implementation, Superuser accessible trough settings)
  • Maybe more...
Install procedure:
As usual with my older firmwares, extract content of zip file to sdcard and install using reset button on back side of device.
UPDATE: On same page you can download XBMC which works on 4.2.2 firmware.
NOTE: This firmware is tested and fully working on VissonTech ATV-102s/Tronsmart Prometheus devices. However I'm not responsible for any damage caused by faulty install, install on other device for which it is not made etc etc... :)
