~~~SOLVED~~~
This new S5 is pissing me off.
Now I can't get visual voicemail to work.
I installed it, activated it, and it gives the message "no voicemails"
I hold the "menu" button and have the option to "Sync Now" which gives me a brief message of "Syncing Voicemails in Progress".
That message disappears and I get a QUICK message that says "Syncing Voicemails failed".
Any ideas?
I DO have Go SMS Pro, if that makes a difference.
Any ideas?
