S
spookydownunder
Guest
Hi guys,
Been searching around but can't find answers, please if you know this question has been asked, just point me in the right direction.
I have a Vodafone Magic (yeah, yeah, I know, stupid right? Fancy wanting an android phone that the supplier will never upgrade past 1.6) But I didn't have that knowledge at the time. While I'm not happy with the phone generally, I have a more specific question.
I have always been happy enough using the stock broswer, although I have tried others too. But Just yesterday a problem turned up, that even using alternate browsers does not help with. When I go onto google site, and into preferences (settings) for google, which goes basically to the same page regardless of browser, I have always been able to save my prefernces, Ie safe search (other than moderate), save location, save searches etc. But yesterday, and since, every time I change a setting, save and then go back into settings, nothing I changed has altered.
Basically rambling, but say I change safe search to strict, press save, goes back to google page, go back into settings, and sure enough safe search is back to moderate.
This used to happen only when I cleared cache.
What the hell have I done to the phone to cause this, it's really quite irritating.
I have turned phone off and back on. I haven't done a factory reset yet, as hoping there is a solution that doesn't invole reinstalling all apps etc. I haven't done a soft reset, because I don't know if one exists.
Thanks in advance,
Steve
Thanks in advance,
Steve
