Mr Burrprint3D
So Currently Im running a stock Razr With No Modifications Etc.Im having an ongoing issue with the Auto Voice Command Dialing numbers and Disturbing my usage whenever I use the 3.5mm Headjack. (Speakers Or headphones) Since I returned My last Razr that had this issue, And problems only Occur After The phone has been used (The problems never occurred immediately ) Is it possible the Jack is just faulty???
Im going to try Using some launchers to see if that stops it...
Is there an app or any other way that can turn off the voice function??? Deleting the App off the phone doesnt seem to work either.
