voice navigation
  • Start date Start date
A
Android Question
Guest
How do I get the voice to work on navigation? it is turned on, volume is up. Sometimes it just comes on temporarily when it hadn't been working previously.
Very strange.
Has turn-by-turn ever worked or did it suddenly stop working? If it never worked, might be worth taking it up with the supplier under warranty.
Alternively, it might be that some of the sound files are missing or maybe just there isn't enough space or memory available to use them.
You could try uninstalling updates on Maps (unfortunately, without rooting you can't uninstall it) then update to the latest version again.
