D
Deleted User
Guest
In the sound/volume settings in v2.2 there used to be a checkbox to link the call volume to the notification volume, so if on the home screen and you used the volume key to reduce the ring volume, it used to reduce the notification volume too.
Now the phone is 2.2.1, this option seems to have gone and to reduce notification volume you have to go into the setting every time
Anyone else have this problem? Am i missing something?
Thanks
Thanks
