Root Volume buttons broken, can't boot to recovery from power off
cmglng
I have a D325, The volume up button does not work while android is booted. But it is working from power off? How do I know? It boots directly into fastboot when i plug in a USB from power off. Is there any other way to access recovery? From fastboot? The broken buttons interrupts the recovery key combo.
I understood you can boot your android. ADB also works when you are in fastboot, but commands are a bit different. I don't no if "fastboot reboot recovery" could do the trick. You may give it shot.
