Help Volumen Key doesn't work
Hi Guys, I really need your help. I've just bought my Huawei U8150(it use android IDEOS), but when i try to use the volum keys, it doesn work, it just put it in vibration mode. The only option to change the volumen is configuring using settings->sounds
Thanks for your help!
Can't you return it for a replacement?
