VPN-Always-On Battery Drain
Jkility
Hi all,
I use a VPN when connected to the internet and I've noticed that if I use the "VPN-Always-On" feature, but I've noticed that when I had it enabled, it uses quite a bit of battery pretty quickly, where as if i use my VPN providers app and connect via that, then I have no problem with the battery drain, it only appears to be when i have VPN-Alway-On do I have a problem with the battery drain,
Any suggestions?
