After the iphone debuted on ATT I switched to VZW because as soon as the iphones hit ATT the service just sucked balls in NYC. within a month it was so bad. If this happens on VZW would upgrading to an LTE phone such as the Droid Thunderbolt be the fix? Is the LTE network using separate bandwidth than the 3g devices? Or if they share the same bandwidth would LTE be the answer anyways?
thanks.
thanks.
